Synthetica LnF
Synthetica LnF
Postby lshah » Wed May 09, 2007 3:45 pm
We are using a modified version of Synthetica lnf in our product.
When I integrate the jide open src JideTabbedPane component into our product, the component does not honor the lnf guide lines.
Is there some special flag/setting I have to do to get the correct lnf?
Lokesh
lshah
Postby JIDE Support » Wed May 09, 2007 5:24 pm
JideTabbedPane has ComponentUIs and corresponding UIDefault for existing L&F such as Windows L&F, Metal L&F, Aqua L&F etc. For Synthetica L&F, you would need something like SyntheticaJideTabbedPaneUI to really keep the ui style of Synthetica. On the other hand, JideTabbedPane supports so many tab shapes and tab styles, I am not even sure if you are willing to spend the time to make all styles and tab shapes working under Synthetica L&F. You might well just use one tab shape such as Office2003 tab shape and just make the tab shape working with Synthetica, which is not hard to do if you look JideTabbedPaneUI source code.
