ListComboBox does not reflect Font Change (JComboBox does)
Postby gtt » Wed May 10, 2023 6:27 am
Hi all,
here is another very special behaviour of the ListComboBox that differs from JComboBox and many others.
Given a FontUiResource, ListComboBox.setFont() will ignore it while others do.
[code]import java.awt.Font;
import javax.swing.JComboBox;
import javax.swing.text.StyleContext;
import com.jidesoft.combobox.ListComboBox;
import com.jidesoft.swing.JideComboBox;
public class ComboBoxDemo_setFont_DifferentComboBoxes {
JFrame frame = new JFrame("ComboBoxes setFont Example");
Font myFont = StyleContext.getDefaultStyleContext().getFont("Snap ITC", 0, 12);
String[] items = new String[] { "Option 1", "Option 2", "Option 3" };
// Uses font
JComboBox<String> jComboBox = new JComboBox<String>(items);
jComboBox.setEditable(false);
jComboBox.setFont(myFont);
// Uses font
JideComboBox jideComboBox = new JideComboBox(items);
jideComboBox.setEditable(false);
jideComboBox.setFont(myFont);
// Does not use font
ListComboBox listComboBox = new ListComboBox(items);
listComboBox.setEditable(false);
listComboBox.setFont(myFont);
JPanel panel = new JPanel();
panel.add(jComboBox);
panel.add(jideComboBox);
panel.add(listComboBox);
frame.getContentPane().add(panel);
frame.pack();
frame.setLocationRelativeTo(null);
[code]
gtt
Re: ListComboBox does not reflect Font Change (JComboBox doe
Postby gtt » Mon May 15, 2023 5:37 am
Is this the right place/context for this topic "ListComboBox"?
- There is a small line in your code, that ignores to set a new setFont(FontUiResource).
- I think if you dismiss this, it will work like JComboBox.
gtt
Postby JIDE Support » Thu Jul 27, 2023 9:47 am
FontUIResource, or any UIResource value, was meant for internal use by the LookAndFeel. This is my understanding of the UIResource interface. If you want to change the font, do not use UIResource.
Postby gtt » Wed Aug 23, 2023 7:14 am
Thanks for this understanding, and i will honor your understanding, but....
1. obviously the behaviour of com.jidesoft.swing.JideComboBox/ListComboBox differs from that of javax.swing.JComboBox in that part. And it is only one line of internal code that makes the difference, but for us impossible to change.
2. In order to display all fonts correctly f.e. in multichar languages like chinese, one must use "CompositeFont".
But this derives from FontUiResource. This chinese version produces the problem.
gtt
Postby gtt » Tue Oct 10, 2023 8:04 am
Sorry, but i cant agree...
Please respect this very simple example.
What should be the reason for this different behaviour of ListComboBox in contrast to JComboBox and JideComboBox.
I would expect them to be echangable.
      // Uses font
      // Uses font
      frame.pack();
2023-10-10 Fonts in ListComboBox.png (19.42 KiB) Viewed 128113 times
gtt
