by aloraine » Wed Apr 12, 2023 8:47 am
I am new to the JIDE Common Layer code base -
Is it possible to build it using JDK 11 or JDK 17?
(Asking because I am working on re-building a Swing application that uses JIDE software components to run under later JDKs. It currently uses JDK 1.8.)
Thank you for your time!
Ann Loraine
UNC Charlotte
aloraine
Users browsing this forum: No registered users and 130 guests
