Exception on macOS with Java 16
Postby robert » Sat Sep 25, 2021 7:39 pm
I am using Jide Common Layer in an application on macOS, using Java 16. Jide works with previous Java versions, but fails with Java 16 on macOS. I receive following exception:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalAccessError: com/apple/laf/AquaPopupMenuUI is not visible
   at java.base/java.lang.ClassLoader.defineClassImpl(Native Method)
   at java.base/java.lang.ClassLoader.defineClassInternal(ClassLoader.java:491)
   at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:452)
   at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
   at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:1167)
   at java.base/jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(BuiltinClassLoader.java:954)
   at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:862)
   at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:820)
   at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:182)
   at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:1111)
   at java.desktop/javax.swing.UIDefaults.getUIClass(UIDefaults.java:721)
   at java.desktop/javax.swing.UIDefaults.getUI(UIDefaults.java:788)
   at java.desktop/javax.swing.UIManager.getUI(UIManager.java:1069)
   at com.jidesoft.swing.JidePopupMenu.updateUI(Unknown Source)
   at java.desktop/javax.swing.JPopupMenu.<init>(JPopupMenu.java:188)
   at java.desktop/javax.swing.JPopupMenu.<init>(JPopupMenu.java:173)
   at com.jidesoft.swing.JidePopupMenu.<init>(Unknown Source)
robert
Re: Exception on macOS with Java 16
Postby JIDE Support » Sat Sep 25, 2021 9:10 pm
You need to use --add-export jvm parameter to expose those classes to JIDE.
Postby robert » Sun Sep 26, 2021 1:18 pm
Thanks, that worked. In case anyone else encounters this issue, this is the jvm argument required:
--add-exports java.desktop/com.apple.laf=ALL-UNNAMED
robert
Users browsing this forum: No registered users and 108 guests
