How to learn, store and restore a table's columns order
Postby glenfiddick » Mon May 24, 2021 1:57 pm
Hello
I’m using the HierarchicalTable class in my program.
You know that users can drag and drop columns to reorder them. I want to be able to show the columns in the same order when that user closes and starts the program again.
Is there a way/method to save and then restore the column order?
(of course always same column names will be used in that table)
(of course i can save the order data into a local file)
(it would be nice to be able to store the width of the column too, but it's not a priority)
Thanks, have a nice day
glenfiddick
Re: How to learn, store and restore a table's columns order
Postby JIDE Support » Mon May 24, 2021 10:58 pm
TableUtils has the methods you are looking for.
Postby glenfiddick » Tue May 25, 2021 1:31 am
JIDE Support wrote:TableUtils has the methods you are looking for.
Well, which ones?
Are you talking about saveColumnOrders that accepts JTable as parameter? (I couldn't find an explaination/documentation on that)
So should I turn whole table object to json, save it in file, and then load it and pass as a parameter?
glenfiddick
Postby JIDE Support » Tue May 25, 2021 7:58 am
setTablePreferenceByName and getTablePreferenceByName
Postby glenfiddick » Wed May 26, 2021 1:27 am
JIDE Support wrote:setTablePreferenceByName and getTablePreferenceByName
Thanks a lot (:
a final question;
I should call getTablePreferenceByName when a change in the table is made (when a column is dragged, table is sorted, column width changed)
Which listeners should I use/add?
(I saw a sortChanged method but couldn't find any other related method)
glenfiddick
Postby glenfiddick » Wed May 26, 2021 4:54 am
a final question;
I have added a mouse listener to the header of the table.
Overriding MouseAdapter's MouseReleased works for me (i guess, for now :D)
Thanks a lot. Have a nice day
glenfiddick
Users browsing this forum: No registered users and 108 guests
