MathUtils bug
MathUtils bug
Postby eugcomax » Sat Mar 17, 2018 2:33 am
max() method in MathUtils has bug that if passed numbers list contains only negative numbers then 0 will be returned.
public static double max(List<Number> numbers) {
        double max = MIN_VALUE;
        for (Number value : numbers) {
            double v = value.doubleValue();
            if (v > max) {
                max = v;
        return max;
Double MIN_VALUE is the smallest positive nonzero value. It should be changed to be -Double.MAX_VALUE. range() method should be fixed as well.
eugcomax
Re: MathUtils bug
Postby JIDE Support » Tue Mar 20, 2018 4:17 pm
Thank for the bug report. I just fixed both and pushed the fix to JIDE Common Layer.
Users browsing this forum: No registered users and 97 guests
