ListComboBox: change the fontsize of the listitems
Postby td84 » Wed Dec 06, 2017 6:36 am
i would like to change the fontsize of the items in a com.jidesoft.combobox.ListComboBox.
My try was to get the renderer and set the font of the Component returned by the renderer, but i get a nullpointerexception:
Can You help me?
public class MyListComboBox extends ListComboBox {
   private ListCellRenderer superRenderer;
   private ListCellRenderer myRenderer;
   public MyListComboBox(Object[] objects, Class<?> clazz) {
      super(objects, clazz);
      initMyRenderer();
   public MyListComboBox(ComboBoxModel model) {
      super(model);
      initMyRenderer();
   public void initMyRenderer() {
      myRenderer = new ListCellRenderer() {
         @Override public Component getListCellRendererComponent(JList list, Object value, int index,
                      boolean isSelected, boolean cellHasFocus) {
            System.out.format("\nmyRenderer() - super: [%s]\n", superRenderer);
            Component comp = superRenderer.getListCellRendererComponent(list, value, index, isSelected, cellHasFocus);
            comp.setFont( new Font("Segoe UI", Font.PLAIN, 14) );
            return comp;
   @Override public ListCellRenderer getRenderer() {
      superRenderer = super.getRenderer();
      System.out.format("\ngetRenderer() - super: [%s]\n", superRenderer);
      return myRenderer;
Thanx in advance,
Daniel
td84
Re: ListComboBox: change the fontsize of the listitems
Postby JIDE Support » Wed Dec 06, 2017 9:48 am
Try ListExComboBox because that's one we will maintain moving forward.
Postby td84 » Wed Dec 06, 2017 4:50 pm
JIDE Support wrote:Try ListExComboBox because that's one we will maintain moving forward.
Ok, thanx. Do you mean instead extends ListComboBox i should write extends ListExComboBox and it will work?
Could you please post a small example?
Thank you,
Daniel
td84
Postby JIDE Support » Wed Dec 06, 2017 11:07 pm
You had the code. Just replace ListComboBox with ListExComboBox.
Postby td84 » Thu Dec 07, 2017 9:57 am
JIDE Support wrote:You had the code. Just replace ListComboBox with ListExComboBox.
Thanx it worked, but now i have 2 other issues:
1) the Look&Feel of the dropdown changed from the "white box" to the "grey box" (see attachments). I would like to have the "white box" (while using ListExComboBox).
2) if i select something in the dropdown, the text that is sowing in the "gery box" has still the old font shape. (but the text in the dropdown-list has the new font shape)
Can you help me with these?
Thanx again,
Daniel
"white box"
"grey box"
td84
Postby JIDE Support » Thu Dec 07, 2017 10:30 am
Make it editable.
Postby td84 » Thu Dec 07, 2017 11:50 am
JIDE Support wrote:Make it editable.
Thanx, but i set it deliberately noneditable. In the old Version (with ListComboBox) i got the right UI even if i set it to noneditable.
Is it no way to keep it noneditable and have the old L&F?
td84
Postby JIDE Support » Thu Dec 07, 2017 12:43 pm
There is no way to do that. That's how JComboBox looks as well.
Postby td84 » Fri Dec 08, 2017 6:20 am
JIDE Support wrote:There is no way to do that. That's how JComboBox looks as well.
Ok, i understand. Do you allow me a last question ?
How can i change the fontsize of the selected text, that is showing in the Textfield not in the Dropdown-list?
I mean: i would like to set the size of "Yes" to 14. Actually it's 12 as you can see on the picture.
Thank you again,
Daniel
td84
Postby JIDE Support » Fri Dec 08, 2017 10:24 am
That's the renderer. Non-editable combobox doesn't have a text field. It used the same list renderer to render the text on the combobox.
Postby td84 » Fri Dec 08, 2017 12:15 pm
JIDE Support wrote:That's the renderer. Non-editable combobox doesn't have a text field. It used the same list renderer to render the text on the combobox.
Ok, than maybe i make something wrong, because the "Yes" in the combobox is still is smaller, then in the dropdown-list.
I also set a bold fontface for dropdown-list, but the text in the combobox doesn't appear in bold.
Could you help to fix it?
Thanx,
Daniel
td84
Postby td84 » Sat Dec 09, 2017 8:00 am
Thanx,
Daniel
I fixed it. Simpli calling setFont() on a ExComboBox instance did it. The renderer has affect on the items in the Dropdown-list but not on the text in the Combobox.
td84
Users browsing this forum: No registered users and 97 guests
