Custom Filter issue with non string type column
Postby gaolifeng » Tue Sep 06, 2016 10:07 am
Hi, I am trying to use the AutoFilterTableHeader in our tables to filter data, but having trouble with the custom filter conditions with non string columns.
No matter what the column data type is, it always show the String filters, e.g. For a Date.class type column, I am expecting to see the following conditions when open the Custom Filter Editor Dialog
Expected Date_Type_Column.png (22.06 KiB) Viewed 133520 times
But I always see the following conditions, seems like it is considered as a String column always.
Actual showing for Date Type Column.png (17.14 KiB) Viewed 133520 times
I wonder what could be wrong with our tablemodel?
Our tableModel has the getColumnClassAt() method returns the correct date types, and our tableModel also implemented the ContextSensitiveTableModel, and has getCellClassAt() returns the correct date types.
Another question, is it possible to have less filters in the Custom Filter Editor Dialog? E.g. to only show Contains filter in the condition drop down.
Frank
gaolifeng
Re: Custom Filter issue with non string type column
Postby JIDE Support » Tue Sep 06, 2016 11:01 am
It should show different list of filters based on the data type. Could you please try to reproduce the issue by modifying AutoFilterTableHeaderDemo.java? Otherwise I can't tell what you did wrong in your code.
Postby gaolifeng » Tue Sep 06, 2016 11:30 am
Hi I am not able to reproduce the issue by using the tableModel from AutoFilterTableHeaderDemo.
final TableModel tableModel = DemoData.createProductReportsTableModel(true, 0);
Our code is the same other than this tableModel. That is why I think problem is in our tablemodel.
Our company purchased support from Jide, how can we get help on this?
Thanks!
gaolifeng
Postby gaolifeng » Tue Sep 06, 2016 1:27 pm
I figured out what is going on.
Turned out in the jide code, it is calling ((ContextSensitiveTableModel) filterableTableModel).getCellClassAt(-1, columnIndex). trying to get -1 row's Cell Class.
And in our code, we can't get -1 row cell class and returned a default String.class.
Now can you please help me with my second question. is it possible to have less filters in the Custom Filter Editor Dialog? E.g. to only show Contains filter in the condition drop down.
Thanks!
gaolifeng
Postby JIDE Support » Tue Sep 06, 2016 4:12 pm
You can do that by using FilterFactoryManager by calling unregisterFilterFactory to remove all other Filter Factories.
