DockableFrame cannot be garbage collected
Postby astaravoitau » Wed Aug 24, 2016 3:13 am
I'm using JIDE docking framework and after I close any DockableFrame it still stays in memory and cannot be processed by the garbage collector.
Jide version 3.3.5.
When I analyze heap dump using visualvm I see no references pointing to the closed frame. VisualVM says "The instance is a GC root".
Should I perform any clean up work on frame closing action?
Attached is a demo project that demonstrates the issue but in this case frame is not a "GC root". It has a reference in KeyboardFocusManager. But I guess there could be the fix that will solve my original problem also
docking.zip
(3.79 KiB) Downloaded 10441 times
astaravoitau
Re: DockableFrame cannot be garbage collected
Postby JIDE Support » Wed Aug 24, 2016 7:20 am
By closing a dockable frame, do you mean close the frame from UI? If so, that's just a call to dockingManager.hideFrame by default. You will have to call dockingManager.removeFrame to allow it to be gc'ed.
