JideMenu Highlight color
Postby eval » Wed Jun 15, 2016 12:44 am
Please help! How can i change the Highlight color of JideMenu and menuItem?
Thank you!
请问怎么在java web B/S系统架构应用中使用数据透视表组件呢?
eval
Re: JideMenu Highlight color
Postby JIDE Support » Thu Jun 16, 2016 5:48 am
The actual painting code is in XxxPainter's paintButtonBackground method. Each style uses a different painter. In your screenshot, it would be Office2007Painter. If you want to change it, you can subclass Office2007Painter to override the paintButtonBackground method, then create a new instance of the painter and put it on UIDefaults "Theme.painter" so that it takes effect.
Postby eval » Mon Mar 13, 2017 4:48 am
Thank you.
This is jideSplitButton. I created new painter class extends Office2007Painter then overridden paintMenuItemBackground method. I also created new JideSplitButtonUI just overridden paintText() & drawStringUnderlineCharAt(...) methods.
It works fine in Windows but the icon did not display properly in Linux. Am i missing some check in Linux?
Please see Images below:
eval
Postby JIDE Support » Mon Mar 13, 2017 10:00 am
Unless you send me a test case, you may have to debug to figure out what's going on. The whole source code for this part is open source anyway so you should be able to debug to figure out what's going on.
Users browsing this forum: No registered users and 102 guests
