ListDataIntelliHints matching any part of a word in the list
Postby 4sfed » Wed Jun 08, 2016 1:09 am
Hi, i have implemented ListDataIntelliHints to display a list of items when a user types into a jTextField. This is working great using this:
ListDataIntelliHints searchBox = new ListDataIntelliHints(searchField, hintsList);
searchBox.setCaseSensitive(false);
However, the matches only occur if the users knows the exact start of the phrase, or at least the first letter(s).
is there any way that i am able to set the search to a "contains" type action so that if the user types in any part of any word then it will provide a list?
eg: user types in "Red"
That will only match any phrase starting with red. I would like it to be able to match any phrase that contains that string, like "The Ball is Red", " The Shoe is Red", "I live in Redding" should all be returned in the list of matches.
Is this possible with the current implementation?
Thanks very much.
4sfed
Re: ListDataIntelliHints matching any part of a word in the
Postby JIDE Support » Wed Jun 08, 2016 7:09 am
You can use the down arrow key to see the list of available words.
Postby 4sfed » Wed Jun 08, 2016 4:11 pm
Thanks. I understand this is possible but not ideal based on the fact that my list contains hundreds of entries, and i would like the user to be able to provide a part of the word they are looking for and the list of matches is narrowed down. is this achievable?
4sfed
Postby JIDE Support » Thu Jun 09, 2016 2:34 pm
IntelliHint uses Searchable internally. Searchable has setFromStart method, set it to false then it will match any where in the string.
Postby 4sfed » Thu Jun 09, 2016 9:43 pm
Ok fantastic.
Could you give me some tips on how to implement this?
Currently all i am doing is this and it all works fine.
How would i go about setting Searchable.setFromStart(false);
Sorry for the probable stupid question, i am still learning.
4sfed
Postby JIDE Support » Fri Jun 10, 2016 2:42 pm
Never mind. I gave the wrong answer. It was my fault. Please override compare method on ListDataIntelliHints to change the comparison to 'contains'.
     * Compares the context with the object in the completion list.
     * @param context the context returned from {@link #getContext()} method.
     * @param o       the object in the completion list.
     * @return true if the context matches with the object. Otherwise false.
    protected boolean compare(Object context, T o);
Postby 4sfed » Sat Jun 11, 2016 12:03 am
Thanks very much. Ended up doing something like this:
if (org.apache.commons.lang3.StringUtils.containsIgnoreCase(listEntry, s)) {
match = true;
So far so good but i will need to continue testing.
4sfed
Users browsing this forum: No registered users and 242 guests
