Customizing CheckBoxListComboBox
Postby td84 » Sun Apr 17, 2016 4:22 pm
Good morning all,
i'm using CheckBoxListComboBox (com.jidesoft.combobox.CheckBoxListComboBox) in a project.
I would like to ask you, if it's possible:
1) to remove the Cancel button from the panel, that contains the items?
2) to add a mouselistener to each item? (I would like to select the checkbox also by double-clicking a list item)
Thank you for your help,
Daniel
td84
Re: Customizing CheckBoxListComboBox
Postby JIDE Support » Mon Apr 18, 2016 9:38 am
See the comments below.
        return new CheckBoxListExComboBox(items, String[].class) {
            protected MultiSelectListChooserPanel createListChooserPanel(ComboBoxModel dataModel, Class<?> clazz, ConverterContext converterContext) {
                return new CheckBoxListChooserPanel(dataModel, clazz, converterContext,
                        getDialogOKAction(), getDialogCancelAction()) {
                    public Component createButtonPanel(int alignment) {
                        Component buttonPanel = super.createButtonPanel(alignment);
// remove the button from the panel. The Cancel button getActionCommand is "Cancel".
                        return buttonPanel;
                    protected void setupList(final JList list) {
                        super.setupList(list);
// add mouse listener here to accept double click
Users browsing this forum: No registered users and 95 guests
