Strange behavior cobining JidePopupMenu and JavaFX
Postby td84 » Mon Apr 11, 2016 3:14 pm
Hello all,
i'm currently working on a project, that uses a JavaFX TreeView. The TreeView must appear in a popup-window (that is showing if you e.g. click on a Jcombobox).
To create the popup-window i use JidePopupMenu. In the example code below, if you click on the text, the popup appears, showing the Tree.
The problem is, i can open the popup only once. For the second time, it doesn't work.
I open the popup in mouseReleased(). The Tree is initialised in createTextScene().
The TreeView example comes from here:
http://www.javaworld.com/article/207449 ... d-swt.html
http://java-buddy.blogspot.co.at/2012/0 ... ample.html
Can you help me, to get the popup working?
Finally it would be nice, if i could open the popup by clicking on a JideComboBox.
Is it possible to assign the TreeView with a JideComboBox? (I mean, if someone clicks on the arrow at the right, then the TreeView apperas instead of the contents of the JideComboBox).
Thank you,
Daniel
package javaprinter;
import javafx.application.Platform;
import javafx.embed.swing.JFXPanel;
import javafx.scene.Scene;
import javafx.scene.control.TreeItem;
import javafx.scene.control.TreeView;
import javafx.scene.layout.StackPane;
import java.awt.BorderLayout;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import javax.swing.JLabel;
import javax.swing.SwingUtilities;
import com.jidesoft.swing.JidePopupMenu;
public class Javafx
static JFXPanel fxPanel = new JFXPanel();
static JidePopupMenu menu = new JidePopupMenu();
private static void initAndShowGUI()
// This method is invoked on Swing thread
final JFrame frame = new JFrame("JavaFX / Swing Integrated");
frame.pack();
frame.setSize(150, 100);
Platform.runLater(new Runnable()
public void run()
initFX(frame);
private static void initFX(JFrame frame)
// This method is invoked on JavaFX thread
// Create the TreeView
final Scene scene = createTextScene();
Javafx.fxPanel.setScene(scene);
// add the TreeView to the popup-window
Javafx.menu.add(Javafx.fxPanel);
// create a panel, that will contain a label
JPanel panel = new JPanel();
/* add a label to the panel */
JLabel label = new JLabel("Right click to get a popup");
panel.add(label);
panel.setSize(120, 100);
/* add a mouse listener to handle the right click */
/* a popup-window appears, that shows a JavaFX-TreeView
* with some element. */
frame.addMouseListener(new MouseAdapter(){
public void mouseReleased(MouseEvent e)
if (e.isPopupTrigger()) {
menu.show(e.getComponent(), e.getX(), e.getY());
System.out.println("\nOpening popup-window.\n");
frame.add(panel, BorderLayout.CENTER);
frame.pack();
System.out.println("\ninit done\n");
* Create the content of the TreeView.
* @return a Scene-instance containing the TreeView.
private static Scene createTextScene() {
TreeItem<String> treeItemRoot = new TreeItem<> ("Root");
TreeItem<String> nodeItemA = new TreeItem<>("Item A");
TreeItem<String> nodeItemB = new TreeItem<>("Item B");
TreeItem<String> nodeItemC = new TreeItem<>("Item C");
treeItemRoot.getChildren().addAll(nodeItemA, nodeItemB, nodeItemC);
TreeItem<String> nodeItemA1 = new TreeItem<>("Item A1");
TreeItem<String> nodeItemA2 = new TreeItem<>("Item A2");
TreeItem<String> nodeItemA3 = new TreeItem<>("Item A3");
nodeItemA.getChildren().addAll(nodeItemA1, nodeItemA2, nodeItemA3);
TreeView<String> treeView = new TreeView<>(treeItemRoot);
StackPane root = new StackPane();
root.getChildren().add(treeView);
Scene scene = new Scene(root, 300, 250);
return scene;
public static void main(String[] arguments)
SwingUtilities.invokeLater(new Runnable()
public void run()
initAndShowGUI();
td84
Re: Strange behavior cobining JidePopupMenu and JavaFX
Postby JIDE Support » Mon Apr 11, 2016 3:33 pm
Unfortunately we don't provide any support for JIDE and JavaFX integration at this moment. Most likely it is out of our control anyway.
Postby td84 » Mon Apr 11, 2016 3:44 pm
Ok, it seems, it would be better to implement a simple popup-window (like JidePopupMenu) by myself...
Can you give me some hint, how to do this?
Thank you in advance,
Daniel
td84
Postby JIDE Support » Mon Apr 11, 2016 4:50 pm
I don't know how to do it in JavaFX either. I haven't updated myself with JavaFX for a while :P
Postby td84 » Mon Apr 11, 2016 11:57 pm
JIDE Support wrote:I don't know how to do it in JavaFX either. I haven't updated myself with JavaFX for a while :P
Ah sorry, forgot to say: the popup window should not be with Javafx. It's ok, with Swing, or Awt ...
How does the class JidePopupMenu realise the popup-window?
Thanx,
Daniel
td84
Postby JIDE Support » Tue Apr 12, 2016 8:17 am
JidePopupMenu is pretty much the same as JPopupMenu. You can look at JPopupMenu source code to see it. Actually JidePopupMenu is also opened source on github under the jide-oss project.
Postby td84 » Tue Apr 12, 2016 8:34 am
Thanx. I realised to combine both together. The problem was, that the TreeView component must be loaded each time from the JavaFX-Thread. Additionally i recreate the popup-window each time the label is clicked.
This should now work.
import javafx.geometry.Pos;
import javafx.scene.layout.VBox;
import java.awt.Graphics;
public class Javafx
static JFXPanel fxPanel;
static JidePopupMenu menu;
static Scene scene;
public static void initAndShowGUI()
// This method is invoked on Swing thread.
// First init the JavaFX-Toolkit by creating a new JFXPanel.
frame.pack();
frame.setSize(300, 100);
setupUI(frame);
private static void setupUI(JFrame frame)
panel.add(label);
* with some element inside it. Everything must be called
* from Platform.runLater() */
public void mouseReleased(final MouseEvent e)
public void run()
//Steps to open the popup-window:
//create scene
//setup (eventual recreate) fxpanel
//create and show menu
fxPanel.removeAll();
menu = new MyPopupMenu();
menu.add(fxPanel);
System.out.format("\n\nOpening popup-window.\n\n");
frame.pack();
for(int a=1; a<=10; a++) {
TreeItem<String> nodeItemAsub = new TreeItem<>("Item A" + a);
nodeItemA.getChildren().add(nodeItemAsub);
VBox root = new VBox();
root.setAlignment(Pos.CENTER);
root.setStyle("-fx-border-style: solid;"
+ "-fx-border-width: 0;"
+ "-fx-border-color: white");
Scene scene = new Scene(root, 120, 250);
return scene;
public void run()
Platform.setImplicitExit(false);
initAndShowGUI();
//Platform.exit();
class MyPopupMenu extends JidePopupMenu {
protected void paintBorder(Graphics g) {
//JFXPanel has also an own border. Painting the
//border of both looks annoying.
//super.paintBorder(g);
td84
Postby td84 » Tue Apr 12, 2016 9:42 am
I've just noticed: if i scroll the tree, the popup closes (even if the mouse cursor is inside of the tree).
Can you help me to solve this?
Thanx again,
Daniel
td84
Postby JIDE Support » Tue Apr 12, 2016 9:44 am
It should close. That's what JPopupMenu do - every mouse click outside will dismiss the popup menu.
Postby td84 » Tue Apr 12, 2016 12:38 pm
But in my case the mouse is inside the popup menu and i don't click, but scroll and the popup closes.
A click inside the popup leaves the window open; that's correct.
td84
Postby td84 » Wed Apr 13, 2016 9:26 am
Could the mouse scroll event be catched in the popup menu?
td84
Postby JIDE Support » Wed Apr 13, 2016 9:40 am
Probably possible. But this really has nothing to do with JIDE. You should look at JPopupMenu source code and try to figure out a solution.
Postby td84 » Thu Apr 14, 2016 12:47 am
Yes, it seems i can't scroll only if i add a JFXPanel to JidePopupMenu.
I added a JPanel, and it worked well.
td84
Postby JIDE Support » Thu Apr 14, 2016 7:54 am
That's why I don't like the idea of JavaFX integration with Swing. Different designs, different UIs, different architectures, thus results in a patchy product.
