ColumnComparatorContextProvider and GroupTables
Postby nad » Mon Jul 27, 2015 8:02 am
I'm currently using a group table and would like to set the ColumnComparatorContextProvider. When I set it as below:
defaultGroupTableModel.setColumnComparatorContextProvider(new DefaultGroupTableModel.ColumnComparatorContextProvider() {
public ComparatorContext getColumnComparatorContext(
TableModel tableModel, int column) {
//Some code to determine if its the correct column / comparator context
The comparator is returned properly when sorting by a grouped column. For example, if I have my method return my comparator for column 5 ,group by column 5, and then sort by column 5, I see my comparator returned and sort correctly.
When I sort by an ungrouped column, I do not see this method being called in the debugger. Is there another method I should be using?
Thank you,
Nick
nad
Re: ColumnComparatorContextProvider and GroupTables
Postby JIDE Support » Mon Jul 27, 2015 10:17 am
We may not call it again if it has been called once as we will cache it internally. Is the correct ComparatorContext used although it was not being called again?
Users browsing this forum: No registered users and 108 guests
