by j-christ » Tue Jun 16, 2015 11:59 pm
In the code below table.loadTableRowSettings(true) is not restoring the selected state after a fireTableDataChanged(). Any ideas why not?
- Code: Select all
private final class SortableSelectionSavingTable extends SortableTable {
private SortableSelectionSavingTable(TableModel arg0) {
super(arg0);
void saveSelection() {
saveTableRowSettings(true);
void restoreSelection() {
loadTableRowSettings(true);
table = new SortableSelectionSavingTable (model);
table.saveSelection();
table.fireTableDataChanged();
table.restoreSelection();
j-christ
by JIDE Support » Wed Jun 17, 2015 8:46 am
You shouldn't use the protected methods as we made them protected for a reason as they are not public APIs. We used them internally which will be conflicting if you also use them. Please call TableUtils.saveSelection and loadSelection in pair instead.
