java.lang.IllegalArgumentException: The icon should not be n
Postby weijenli » Wed May 20, 2015 12:41 pm
I have a Java process that starts another Java GUI process (which uses JIDE).
When I ran it I saw a lot of "Can't create cache file!".
and saw this stacktrace:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: The icon should not be null.
at com.jidesoft.icons.MenuCheckIcon.<init>(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetWindowsUtils.initComponentDefaultsWithMenu(Unknown Source)
at com.jidesoft.plaf.LookAndFeelFactory.installJideExtension(Unknown Source)
at com.jidesoft.plaf.LookAndFeelFactory.installDefaultLookAndFeelAndExtension(Unknown Source)
Running the GUI process directly won't see the exception.
It only happens when the GUI process is started from another process using Runtime.getRunTime.exec
How do I solve this issue?
What and where are these "cache file" created?
Weijen
weijenli
Re: java.lang.IllegalArgumentException: The icon should not
Postby JIDE Support » Wed May 20, 2015 3:29 pm
The error is from JDK source code ImageIO. We are not sure what's going on under the hood. Could it be a permission issue?
Postby weijenli » Thu May 21, 2015 5:43 am
Yes, this is very much like a permission issue.
This is what I have:
JavaProcessA uses Runtime.getRunTime.exec to start JavaProcessB, and JavaProcessB is a JIDE GUI.
We run this on Windows.
If the user is Administrator, then everything is fine.
However, if the user is not Administrator, JavaProcessB crashes.
The issue seems JIDE writes some temporary cache, because I see "Can't create cache file!" in the ErrorStream.
But how do we setup the user permission? The user cannot be administrator.
At least we should find out where this cache file is written, so we can manually change the permission of a specific folder.
One thing to note, it works well if we run JavaProcessB directly from command line.
Weijen
weijenli
Users browsing this forum: No registered users and 127 guests
