PivotTablePane DataTable how to add "Auto Resize ... " popup
Postby astaravoitau » Tue Mar 17, 2015 11:40 pm
How to add "Auto Resize All Columns" and "Auto Resize This Column" to the Popup menu to the PivotTablePane.dataTable?
Which way is preferable?
astaravoitau
Re: PivotTablePane DataTable how to add "Auto Resize ... " p
Postby JIDE Support » Wed Mar 18, 2015 7:37 am
You can use PivotTablePane#setDataTablePopupMenuCustomizer to do it. There are also setHeaderTablePopupMenuCustomizer and setPopupMenuCustomizer in case you need them. You can refer to the javadoc to find out what they are for.
