AdvancePageTableModel and pageSize
Postby XDMJ » Fri Feb 13, 2015 3:47 am
we are using AdvancePageTableModel and having issues with pageSize.
When using protected AdvancePageTableModel(int pageSize) pageSize seems to be always 25, whatever pageSize specified in the constructor.
Is there a limition on the implementation that prevents from using pageSize ?
Best regards
XDMJ
Re: AdvancePageTableModel and pageSize
Postby JIDE Support » Fri Feb 13, 2015 7:49 am
I checked the code and the page size you passed in the constructor is indeed used. I searched the code and didn't see anywhere we ever hard coded 25. Could it because something else in your code?
Postby XDMJ » Fri Feb 13, 2015 8:16 am
Thanks for the reply
After some investigation, it seems that connecting the PageNavigationBar resets the pageSize on the PageNavigationSupport model to 25 ...
This is how we create the PageNavigationBar :
PageNavigationBar pageNavigationBar = new PageNavigationBar(table);
A workaround is to set the pageSize right after but this generates 2 'refresh' on the model, one with 25 elements, the other with pageSize specified which is quite bad.
Hope this helps
XDMJ
Postby JIDE Support » Fri Feb 13, 2015 8:30 am
I see. That page size was calculated from the table viewport height. I think we would rather keeping it.
        int pageSize = table.getPreferredScrollableViewportSize().height / table.getRowHeight();
Postby XDMJ » Fri Feb 13, 2015 8:34 am
Is there a way to set it manually instead of being calculated ?
XDMJ
Postby JIDE Support » Fri Feb 13, 2015 9:34 am
Right now there is no way to not set the page size. I will try to come up with something so that if you set your own page size, we will not mess up with it. Will keep you posted.
