DocumentComponent's title truncate
Postby cage78 » Tue Oct 28, 2014 8:06 pm
I have a component which extends DocumentComponent class. However, I always have document's title truncated when the title is too long (>30 characters). The truncation is happened in the middle of the title (e.g., "xxxTitle...1yyy").
My question is that is there anyway to change the position of truncation (e.g., truncate from the begin of title or truncate at the end of the title)? Or in the worst case, can we set it to NOT truncate the title at all?
cage78
Re: DocumentComponent's title truncate
Postby JIDE Support » Tue Oct 28, 2014 8:30 pm
You can change how it is truncated using DocumentPane#setTitleConverter. You can use a instance of DefaultStringConverter(Integer.MAX_VALUE, 0) if no truncated at all or DefaultStringConverter(30, 0) if truncating at the end only.
Postby cage78 » Wed Oct 29, 2014 3:45 pm
Thanks. It works perfectly
cage78
Users browsing this forum: Bing [Bot] and 87 guests
