row selection by right click
Postby Falko » Tue Oct 14, 2014 4:20 am
hi,
can you pleas help me to select one row on right click in row header table.
the use case is to click right on the row header table than to
select the row in row header table and data table
and edit the row in data table.
rowHeaderTable.addMouseListener(new MouseAdapter() {
            public void mouseClicked(MouseEvent e) {
            if (SwingUtilities.isRightMouseButton(e) ) {
            final PivotTablePane pivotTablePane = activePivotTable.getPivotTablePane();
                        final JideTable rowHeaderTable = (JideTable) activePivotTable.getPivotTablePane().getRowHeaderTable();
                        final JTable dataTable = pivotTablePane.getDataTable();
                  //this works, listener get invoked
                        //rowHeaderTable.selectAll();
                        //dataTable.selectAll();
                  // this works, listener get invoked
                        //rowHeaderTable.clearSelection();
                        //dataTable.clearSelection();
                  // depends on previous clear or selectAll
                  int[] rowsd0 = dataTable.getSelectedRows();
                  // allways empty
                        int[] rowsh0 = rowHeaderTable.getSelectedRows();
               // find out clicked row
                        int rowcount = pivotTablePane.getRowHeaderTable().getRowCount();
                        int rowHeight = e.getComponent().getHeight() / rowcount;
                        int componentHeight = e.getY();
                        final int clickedRow = componentHeight / rowHeight;
               // this all doesn't work, listener not invoked
               dataTable.setRowSelectionInterval(clickedRow, clickedRow);
                        dataTable.setColumnSelectionInterval(clickedRow, clickedRow);
                        dataTable.getSelectionModel().setSelectionInterval(clickedRow, clickedRow);
                        dataTable.getColumnModel().getSelectionModel().setSelectionInterval(clickedRow, clickedRow);
                        rowHeaderTable.setRowSelectionInterval(clickedRow, clickedRow);
                        rowHeaderTable.setColumnSelectionInterval(clickedRow, clickedRow);
                        rowHeaderTable.getSelectionModel().setSelectionInterval(clickedRow, clickedRow);
                        rowHeaderTable.getColumnModel().getSelectionModel().setSelectionInterval(clickedRow, clickedRow);
                  // nothing changed
                  int[] rowsd1 = dataTable.getSelectedRows();
                        int[] rowsh1 = rowHeaderTable.getSelectedRows();
by the way. the other listener methods don't get invoked. this is strange.
rowHeaderTable.getSelectionModel().addListSelectionListener(new ListSelectionListener() {
            public void valueChanged(ListSelectionEvent e) {
                System.out.println("invoked");
      rowHeaderTable.getTableSelectionModel().addTableSelectionListener(new TableSelectionListener() {
            public void valueChanged(TableSelectionEvent e) {
cheers
Falko
Re: row selection by right click
Postby JIDE Support » Tue Oct 14, 2014 7:18 am
This forum is for the open source JIDE Common Layer, not for the JIDE Pivot Grid. Please use the pivot grid forum instead. It also looks like the maintenance for your company expired in 2013. We would appreciate if you can renew your maintenance before asking technical questions on the forums.
Users browsing this forum: No registered users and 201 guests
