Code Editor CTRL+SPACE not working
Postby aryanarvind » Sat Oct 11, 2014 8:35 am
I've spent more than 12 hrs trying to figure out how to get the CTRL+SPACE to work on the code editor with customer list of data.
import java.lang.reflect.Method;
import java.util.ArrayList;
import java.util.List;
import com.jidesoft.editor.CodeEditor;
import com.jidesoft.editor.ListDataCodeEditorIntelliHints;
import com.jidesoft.editor.caret.CaretEvent;
import com.jidesoft.editor.caret.CaretListener;
public class HintsProvider {
   public static Object[] loadHints(String text, int caretPosition) {
      List<String> values = new ArrayList<String>();
      String temp = text.substring(0, caretPosition - 1);
      temp = temp.substring(temp.lastIndexOf("\n") + 1).trim();
         Class clazz = Class.forName(temp);
         for (Method method : clazz.getMethods()) {
            values.add(method.getName());
      } catch (ClassNotFoundException e) {
      return values.toArray();
      final CodeEditor ce = new CodeEditor();
      @SuppressWarnings("unchecked")
      final ListDataCodeEditorIntelliHints hints = new ListDataCodeEditorIntelliHints(
            ce, new ArrayList<String>());
      ce.getCaretModel().addCaretListener(new CaretListener() {
         public void caretUpdated(CaretEvent caretEvent) {
               hints.setCompletionList(HintsProvider.loadHints(
                     ce.getText(), ce.getCaretPosition()));
               System.out.println(hints.getCompletionList());
            } catch (Exception e) {
      JFrame frame = new JFrame();
      frame.getContentPane().add(ce);
      frame.pack();
Could you please let me know whats wrong with this code?
aryanarvind
Re: Code Editor CTRL+SPACE not working
Postby JIDE Support » Sun Oct 12, 2014 11:02 am
Attached please find the revised code to make your demo working although there will be a lot of more work to get it really working for generic Java code editing.
1. You don't need to use caret listener as in updateHints method, we will provide the context that you can use to find out what hints to provide.
2. Since the hints are used to auto-complete, it must have the same leading characters. That's why in the completion list, you need to add the complete strings, not just the missing part.
Right now if you type in "javax.swing.JLabel." and press ctrl-space, you will see all the methods. You can also see "javax.swing.JLabel.get" then ctrl-space to see all getters.
   public static Object[] loadHints(String context) {
      String temp = context.substring(0, context.lastIndexOf("."));
            values.add(temp + "." + method.getName());
               ce, new ArrayList<String>()) {
           public boolean updateHints(Object context) {
               Object[] list = HintsProvider.loadHints("" + context);
               setCompletionList(list);
               return super.updateHints(context);
      frame.pack();
Postby aryanarvind » Mon Oct 13, 2014 7:48 am
Thanks for a quick response.
I see that you had to append the Class to the begining of the values?
Removing that does not display the string in the list box, is there a reason for it?
import java.awt.Color;
import java.awt.Dimension;
import javax.swing.BorderFactory;
import javax.swing.ScrollPaneConstants;
         getMethods(values, temp);
         if (values.isEmpty()) {
            // Check if it's variable.
         System.out.println(values);
   private static void getMethods(List<String> values, String temp)
         throws ClassNotFoundException {
      Class<?> clazz = Class.forName(temp);
         StringBuffer sb = new StringBuffer();
         // sb.append(temp);
         // sb.append(".");
         sb.append(method.getName());
         sb.append("(");
         int i = 0;
         for (Class<?> type : method.getParameterTypes()) {
            if (i != 0) {
               sb.append(", ");
            sb.append(type.getSimpleName() + "arg" + i++);
         sb.append(")");
         values.add(sb.toString());
      @SuppressWarnings({ "rawtypes", "unchecked" })
      final JScrollPane codeEditorScrollPane = new JScrollPane(ce);
            .setHorizontalScrollBarPolicy(ScrollPaneConstants.HORIZONTAL_SCROLLBAR_AS_NEEDED);
            .setVerticalScrollBarPolicy(ScrollPaneConstants.VERTICAL_SCROLLBAR_AS_NEEDED);
      codeEditorScrollPane.setBorder(BorderFactory
            .createLineBorder(Color.DARK_GRAY));
      frame.getContentPane().add(codeEditorScrollPane);
      frame.setSize(new Dimension(300,350));
aryanarvind
Postby JIDE Support » Mon Oct 13, 2014 8:20 am
Auto completion is to auto complete the rest based on the existing content. We will actually do a match to filter the hints you provided. If the beginning of the hints don't match with the context, we will filter them out. That's why you have to provide the complete strings, not just the portion to be completed. If you don't like the hint popup to show the complete strings, you can provide a custom list cell renderer to remove them.
Users browsing this forum: Bing [Bot] and 85 guests
