by vishal » Thu Aug 28, 2014 2:59 am
I am trying to work with Jide examples (TreeTable FileSystem) example to create horizantal scrollbar in it, when tree nodes are expanding.
I tried many APIs like setting preferred size of Frame of scrollpane but it didn't shows up. Vertical scrollbar is works but not horizontal.
Please advice, or how Horizontal scroll bar can be drawn ??
-Vishal
vishal
by JIDE Support » Thu Aug 28, 2014 7:15 am
Have you tried table.setAutoResizeMode method?
by vishal » Thu Aug 28, 2014 7:19 am
yes indeed - just now resolved the problem
Thanks for help .
vishal
Users browsing this forum: Bing [Bot] and 89 guests
