Filter preferences on a table not working with Integers
Postby vidhut » Tue Jul 08, 2014 5:34 pm
I am having issues where the table is not saving the filter preferences when i do a save preferences. This happens only on integers or a number field, however it works perfectly with strings
The steps to repo this issue is run the attached class
1.Filter on # of year and pick any number
2.save the preference
3.now change the filter to "ALL"
4.click Load
The data is not displayed in the table.
I am attaching a copy of my test case.
filterTest.java
(5 KiB) Downloaded 3312 times
This seems to be a bug in the Library as i was able to reproduce the same on FilterableTableDemo.java on jide demos.
Anyone experiencing this issue too?
Would appreciate any help on this.
vidhut
Re: Filter preferences on a table not working with Integers
Postby JIDE Support » Tue Jul 08, 2014 9:30 pm
You will have to return the correct data type at the getColumnClass correctly. It is very important to implement this method if using the JIDE Grids. We don't depend on the actual data to determine the data type as the table could be empty but depending on the getColumnClass or sometimes getCellClassAt of the ContextSensitiveTableModel to determine the data type.
        TableModel model = new DefaultTableModel(data, columnNames) {
            public Class<?> getColumnClass(int columnIndex) {
                if(columnIndex == 3) return Integer.class;
                else if (columnIndex == 4) return Boolean.class;
                return super.getColumnClass(columnIndex);
        final JTable table = new JTable(model);
