DockableFrame with transparent glasspane
Postby jeo » Thu Apr 24, 2014 8:36 am
I have a solution to display a waiting panel (typical with an spinning wheel) in swing Frames, when I try to use the same solution with DockableFrame it doesn't work anymore, I know Dockable frame doesn't extend Frame or any other swing Frame related classes, but it has the method setGlassPane so there should have a similar functionality.
To get the transparency I'm setting a JPanel as a glass pane, where i set the background color and redefine the following method:
   protected Graphics getComponentGraphics(Graphics g) {
      g = super.getComponentGraphics(g);
      Graphics2D g2d = (Graphics2D) g;
                g2d.setRenderingHint(RenderingHints.KEY_ANTIALIASING, RenderingHints.VALUE_ANTIALIAS_ON);
                g2d.setComposite(AlphaComposite.getInstance(AlphaComposite.SRC_OVER, 0.03f));
      return g2d;
Can someone advice about any other way to achieve transparency using a glass pane in DockableFrame. I'm also having issues displaying the gif image in the glass pane but first thing first.
J
jeo
Re: DockableFrame with transparent glasspane
Postby JIDE Support » Thu Apr 24, 2014 9:42 am
Unfortunately DockableFrame got the method because it uses JRootPane which has glass pane. However it doesn't provide any code to support the glass pane. You may use JLayeredPane which DockableFrame does support.
