by nad » Mon Mar 31, 2014 5:35 am
I have a table that currently holds color objects within one of the columns. Is there a way to have the converter context for color only display the color as a small rectangle? For example, ColorConverter.CONTEXT_RGB displays the colored recantangle and the RGB values.
Nick
nad
by JIDE Support » Mon Mar 31, 2014 6:53 am
You cannot only use converter to do it because the converter only can convert the value to string. It cannot paint a color icon. What you need is a CellRenderer/CellEditor. Our ColorCellRenderer can already configured to only show a color icon. Please refer to examples\G26.ContextSensitiveTable\ContextSensitiveTableDemo.java for a complete demo that shows you how to do it.
