by mwendt » Wed Mar 19, 2014 4:42 am
I'm using JIDE 3.5.13 and a CheckBoxTree. Is there a way to set the icons for collapsed/expanded nodes (root handlers) per instance?
I've tried using putClientProperty("Tree.expandedIcon", ...), but this does not work.
Thanks in advance.
mwendt
by JIDE Support » Wed Mar 19, 2014 9:30 am
We didn't add any extra in CheckBoxTree. Whatever you can do to the JTree, it is the same as CheckBoxTree. As far as I know, you need to get the BasicTreeUI (only if you are using BasicTreeUI or its subclasses) and call setExpandedIcon on the UI class.
by mwendt » Wed Mar 19, 2014 9:54 am
Thank you. I did it that way in the meantime anyway and it works
For the sake of completeness:
- Code: Select all
// change icons for a tree instance
final BasicTreeUI btui = (BasicTreeUI) tree.getUI();
btui.setExpandedIcon(myExpandIcon);
btui.setCollapsedIcon(myCollapseIcon);
} catch (ClassCastException cce) { ... }
// OR: change icons globally
// UIManager.put("Tree.expandedIcon", myExpandIcon);
// UIManager.put("Tree.collapsedIcon", myCollapseIcon);
mwendt
