left alignment in Property Pane for numeric data
Postby staiger » Mon Mar 17, 2014 7:08 am
Hi Jide friends,
I want to change the alignment of my numeric data in a propertypane generally to left align.
Is this possible?
I have the following code (copied from JIDE Demo)
SimpleProperty prop = new SimpleProperty("Double", "The row is intended to show how to create a cell to input a double.", Double.class);
pane.getPropertyList().add(prop);
CellEditorManager.registerEditor(Double.class, new CellEditorFactory()
public CellEditor create()
DoubleCellEditor editor = new DoubleCellEditor();
DecimalFormat format = new DecimalFormat();
format.setMinimumFractionDigits(2);
format.setMaximumFractionDigits(10);
DoubleConverter editorConverter = new DoubleConverter(format);
editor.setConverter(editorConverter);
return editor;
Norbert
staiger
Re: left alignment in Property Pane for numeric data
Postby JIDE Support » Mon Mar 17, 2014 9:03 am
A quick way to do is to use CellEditorManager.addCellEditorCustomizer.
      CellEditorManager.addCellEditorCustomizer(new CellEditorManager.CellEditorCustomizer() {
          public void customize(CellEditor cellEditor) {
              if(cellEditor instanceof NumberCellEditor) {
                  ((NumberCellEditor) cellEditor).getTextField().setHorizontalAlignment(SwingConstants.LEADING);
Postby staiger » Tue Mar 18, 2014 12:50 am
sorry, but this does not work in my Application.
the alignment is still right.
I use the following code:
public void register4Double()
format.setMaximumFractionDigits(2);
DoubleConverter converter = new DoubleConverter(format);
ObjectConverterManager.registerConverter(Double.class, converter);
return editor;
private void registerLeftAlign()
((NumberCellEditor) cellEditor).getTextField().setHorizontalAlignment(SwingConstants.LEFT);
staiger
Postby JIDE Support » Tue Mar 18, 2014 7:47 am
It should work. Can you debug and see if the CellEditorCustomizer is called at all?
Postby staiger » Tue Mar 18, 2014 8:07 am
the setHorizontalAlignment method is called when clicking to the long field.
But the field remains right aligned.
Thank you
Norbert
staiger
Postby JIDE Support » Tue Mar 18, 2014 8:25 am
My fault. The horizontalAlignment flag was later reset in the NumberCellEditor.java to TRAILING. Whatever you set to horizontalAlignment in CellEditorCustomizer got lost, since it was called before the same call in NumberCellEditor. On one hand, I will modify NumberCellEditor to call setHorizontalAlignment earlier so that CellEditorCustomizer will have effect. I will let you know when we have a new release for it. On the other hand, you can use CellStyle feature to control the cell alignment as well. Just define a CellStyle constant with CellStyle#setHorizontalAlignment(SwingConstants.LEADING) then return it for the cell you want to align left in the getCellStyleAt method.
Postby staiger » Tue Mar 18, 2014 9:12 am
Thank you very much.
Norbert
staiger
Postby JIDE Support » Fri Apr 04, 2014 10:36 am
Just so you know, JIDE 3.5.15 is released which fixed this bug.
Users browsing this forum: Bing [Bot] and 89 guests
