TristateCheckbox
TristateCheckbox
Postby poregan » Wed Mar 12, 2014 8:40 am
Is is possible to easily adjust the color of the value displayed within the tristate checkbox e.g. the tick to indicate checked or the block square to indicate mixed.
I have a requirement to change this color but obviously the likes of background and foreground setting on the checkbox are only affecting the outside of the checkbox rather than the inner symbol as described above.
Any suggestions?
poregan
Re: TristateCheckbox
Postby JIDE Support » Wed Mar 12, 2014 8:49 am
Not easy to get a consistent solution. The icon is actually painted by Windows's native code if you are on Window. If you paint the icon yourself, then you can do whatever you want but that's clearly not what you want to do. All the source code is at the jide-oss on the github. TristateCheckBoxIcon is the icon class for all other L&Fs while WindowsIconFactory defines the icon for the Windows L&F which delegates to the native code. MetalIconFactory is for the Metal L&F which you can customize.
