CheckBoxListComboBox search tooltip disappears.
Postby astaravoitau » Thu Feb 27, 2014 12:10 pm
We are using CheckBoxListComboBox in our application. When user expands combobox and then starts typing the text to search any item in the list, a small tooltip appears and displays user's input. User finds an item and selects it -> small tooltip disappears. User wants to find and select another item and starts typing, but small tooltip does not show up anymore. Is there any fix for this little annoying issue? Thanks
astaravoitau
Re: CheckBoxListComboBox search tooltip disappears.
Postby JIDE Support » Thu Feb 27, 2014 12:59 pm
We will try to fix it. For now, you can press ESCAPE key after you mouse click to select the check box, then search tooltip will show again when you type in something.
Postby JIDE Support » Fri Feb 28, 2014 1:53 pm
Just so you know, this bug is fixed in the 3.5.14 which was just released.
