by poregan » Thu Feb 27, 2014 10:15 am
In the Hierarchical Table I want to paint to the background color of the margin that is directly under the expand/collaspe node. Is this possible?
I have tired to setMarginBackground but this doesnt paint the area under the icon rather just the space under the name of the parent node.
Any suggestions?
poregan
by JIDE Support » Thu Feb 27, 2014 11:03 am
You can call HierarchicalTable#setMarginBackground to change the color.
by poregan » Thu Feb 27, 2014 11:27 am
As mentioned I have already tried this and it will paint the area around the expand/collapse icon and will also paint the area to the left of the child component but only to the point where the expand " L " icon begins.
I want to paint the panel containing the L (expand) icon.
poregan
by JIDE Support » Thu Feb 27, 2014 11:32 am
Currently there is no way to paint different colors for the background of the expand/collapse icon and the "L" line. You will have to write your code. The L line's background is painted in TreeLikeHierarchicalPanel. It extends HierarchicalTable and have this paintComponent. You can modify it to paint yourself.
- Code: Select all
protected void paintComponent(Graphics g) {
super.paintComponent(g);
g.setColor(UIDefaultsLookup.getColor("Tree.hash"));
if (getComponentOrientation().isLeftToRight()) {
g.drawLine(ExpandablePanel.LEFT_MARGIN / 2, 0, ExpandablePanel.LEFT_MARGIN / 2, ExpandablePanel.LEFT_MARGIN);
g.drawLine(ExpandablePanel.LEFT_MARGIN / 2, ExpandablePanel.LEFT_MARGIN, ExpandablePanel.LEFT_MARGIN, ExpandablePanel.LEFT_MARGIN);
else {
g.drawLine(getWidth() - ExpandablePanel.LEFT_MARGIN / 2 - 2, 0, getWidth() - ExpandablePanel.LEFT_MARGIN / 2 - 2, ExpandablePanel.LEFT_MARGIN);
g.drawLine(getWidth() - ExpandablePanel.LEFT_MARGIN / 2 - 2, ExpandablePanel.LEFT_MARGIN, getWidth() - ExpandablePanel.LEFT_MARGIN, ExpandablePanel.LEFT_MARGIN);
by poregan » Thu Feb 27, 2014 11:35 am
Excellent Thank you.
poregan
by poregan » Thu Feb 27, 2014 11:38 am
By calling setBackground on the TreeLikeHierarchicalPanel that I return in the TableComponentFactory.createChildComponent I was able to achieve what I was looking for.
Thanks for your help.
poregan
Users browsing this forum: Bing [Bot] and 91 guests
