JideSplitButton rounded border
Postby sgr » Tue Feb 11, 2014 2:18 am
I have been trying to make JideSplitButton(without modifying BasicJideSplitButtonUI) to use a rounded border, same as the one used by the basic JButton but with no success.
I have inspected a bit the BasicJideSplitButtonUI class and observed that custom borders are ignored completely by the painting code.
So the question is: How can I customize the JideSplitButton or any jide button to look more like the rest of the non-jide buttons?
I am running on Windows 7 Prof x64 with JDK 1.7.0_45. Ideally I think the BasicJideSplitButtonUI class should use the proper border based on the current L&F and/or button style.
I have modified the JideSplitButtonDemo to add a new JButton and use the setBorder() method on JideSplitButton as follows to show you what I am trying to do:
 * @(#)JideSplitButtonDemo.java 3/19/2005
 * Copyright 2002 - 2005 JIDE Software Inc. All rights reserved.
import com.jidesoft.swing.JideSplitButton;
import com.jidesoft.swing.JideSwingUtilities;
import com.jidesoft.swing.JideToggleSplitButton;
import javax.swing.event.PopupMenuEvent;
import javax.swing.event.PopupMenuListener;
 * Demoed Component: {@link com.jidesoft.swing.JideButton} <br> Required jar files: jide-common.jar, jide-components.jar
 * <br> Required L&F: Jide L&F extension required
public class JideSplitButtonDemo extends AbstractDemo {
    private static final long serialVersionUID = -8707660318949717143L;
    private JideSplitButton[] _buttons;
    public JideSplitButtonDemo() {
    public String getName() {
        return "JideSplitButton Demo";
    public String getProduct() {
        return PRODUCT_NAME_COMMON;
        return "JideSplitButton is a combination of button and menu. It has a button part just like JideButton but it also has a menu part where a popup menu could be added.\n" +
                "\n" +
                "Demoed classes:\n" +
                "com.jidesoft.swing.JideSplitButton\n";
        int numberOfButtons = 8;
        JPanel panel = new JPanel(new GridLayout(numberOfButtons+1, 1, 2, 2));
        _buttons = new JideSplitButton[numberOfButtons];
        int i = 0;
        _buttons[i++] = createJideSplitButton("Copy the text", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.COPY));
        _buttons[i++] = createJideSplitButton("Cut the text", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.CUT));
        _buttons[i++] = createJideSplitButton("Paste the text", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.PASTE));
        _buttons[i++] = createJideSplitButton("Delete the text", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.DELETE));
        _buttons[i++] = createJideSplitButton("Refresh the content", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.REFRESH));
        _buttons[i++] = createJideSplitButton("Undo the action", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.UNDO));
        _buttons[i++] = createJideSplitButton("Redo the action", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.REDO));
        _buttons[i] = createJideSplitButton("Action history", ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.HISTORY));
        for (JideSplitButton button : _buttons) {
            panel.add(button);
        panel.add(new JButton("JButton"));
        return JideSwingUtilities.createTopPanel(panel);
        return "B4.JideButton";
            public void run() {
                showAsFrame(new JideSplitButtonDemo());
        JPanel switchPanel = new JPanel(new GridLayout(0, 1, 2, 2));
        final JRadioButton style1 = new JRadioButton("Toolbar Style");
        final JRadioButton style2 = new JRadioButton("Toolbox Style");
        final JRadioButton style3 = new JRadioButton("Flat Style");
        ButtonGroup buttonGroup = new ButtonGroup();
        buttonGroup.add(style1);
        buttonGroup.add(style2);
        buttonGroup.add(style3);
        switchPanel.add(new JLabel("Styles:"));
        switchPanel.add(style1);
        switchPanel.add(style2);
        switchPanel.add(style3);
        style1.setSelected(true);
        ItemListener itemListener = new ItemListener() {
                if (style1.isSelected()) {
                        button.setButtonStyle(JideSplitButton.TOOLBAR_STYLE);
                else if (style2.isSelected()) {
                        button.setButtonStyle(JideSplitButton.TOOLBOX_STYLE);
                else if (style3.isSelected()) {
                        button.setButtonStyle(JideSplitButton.FLAT_STYLE);
        style1.addItemListener(itemListener);
        style2.addItemListener(itemListener);
        style3.addItemListener(itemListener);
        switchPanel.add(new JLabel("Options: "));
        final JCheckBox option1 = new JCheckBox("Button part enabled");
        final JCheckBox option2 = new JCheckBox("Both parts enabled");
        final JCheckBox option3 = new JCheckBox("Button part selected");
        final JCheckBox option4 = new JCheckBox("Always Dropdown");
        switchPanel.add(option1);
        switchPanel.add(option2);
        switchPanel.add(option3);
        switchPanel.add(option4);
        option1.setSelected(true);
        option1.addItemListener(new ItemListener() {
                    button.setButtonEnabled(option1.isSelected());
        option2.setSelected(true);
        option2.addItemListener(new ItemListener() {
                    button.setEnabled(option2.isSelected());
        option3.addItemListener(new ItemListener() {
                    button.setButtonSelected(option3.isSelected());
        option4.addItemListener(new ItemListener() {
                    button.setAlwaysDropdown(option4.isSelected());
        return switchPanel;
    static JideSplitButton createJideSplitButton(String name, Icon icon) {
        final JideSplitButton button = new JideSplitButton(name);
        button.setIcon(icon);
        button.add(new AbstractAction("Sample Menu Item") {
        button.addActionListener(new ActionListener() {
                System.out.println("button is clicked");
        button.getPopupMenu().addPopupMenuListener(new PopupMenuListener() {
            public void popupMenuWillBecomeVisible(PopupMenuEvent e) {
                System.out.println("menu is clicked");
            public void popupMenuWillBecomeInvisible(PopupMenuEvent e) {
            public void popupMenuCanceled(PopupMenuEvent e) {
        button.setFocusable(false);
        button.setBorderPainted(true);
        button.setBorder(UIManager.getBorder("Button.border"));
        return button;
    static JideSplitButton createJideToggleSplitButton(String name, Icon icon) {
        final JideSplitButton button = new JideToggleSplitButton(name);
        return button;
And here's a screenshot of the end result on my environment:
JideSplitButtonDemo
sgr
Re: JideSplitButton rounded border
Postby JIDE Support » Tue Feb 11, 2014 8:11 am
Unfortunately you will have to write your own SplitButtonUI to do it. The two parts can be pressed separately prevents the split button to use a simple border.
Postby sgr » Sat Feb 15, 2014 1:49 am
Not really the answer I was hoping for.... :)
Since this is not really a show-stopper and I currently do not have the time to do it my self I will have to live with it,
at least until the users start to really to complaint about it...
Anyways, I will let you know in case I have a successful attempt at this.
sgr
Users browsing this forum: Bing [Bot] and 89 guests
