JIDE Collapsible pane - Security Exception
Postby pranesh93 » Wed Jan 29, 2014 11:25 pm
I have been trying to implement JIDE collapsible pane for which i have downloaded the JIDE_demo.jnlp file and tried to understand the source code. I tried to build my own GUI but the exception java.lang.SecurityException : Class "Abstract Demo"'s signer information does not match signer information of other classes in the same package was thrown .
The exact exception i am getting
So i tried to execute the entire source code as it is in the jnlp file. But that also throws the same exception. I don't understand what is the reason for this !
jar files added : JIDE-common.jar. JIDE-components.jar
pranesh93
Re: JIDE Collapsible pane - Security Exception
Postby JIDE Support » Thu Jan 30, 2014 12:01 am
It sounds like you might include the jide-demo.jar in your class path by mistake. If so, please remove it and only use the jars from the evaluation package you downloaded and open the example projects in the eval package to run the demos.
