JideSplitButton not working on JidePopup using Java 7
Postby naanab » Mon Jan 06, 2014 7:19 am
Dear Sir, Madam,
In our transition to Java 7 we came across some functionality that doesn't seem to work as before. We are using a JideSplitButton shown on a JidePopup. Using Java 7 the menu items don't work anymore. Using Java 6 everything works as expected.
When running the following demo, using jdk1.7.0_45 on OSX, selecting a menu item does nothing. We are using Jide 3.5.12.
import java.awt.BorderLayout;
import java.awt.Dimension;
import javax.swing.JButton;
import javax.swing.JMenuItem;
import com.jidesoft.popup.JidePopup;
import com.jidesoft.swing.JideSplitButton;
public class JidePopupDemo extends JidePopup {
    public JidePopupDemo() {
        super();
        JButton button = new JButton("Close");
        button.addActionListener(new ActionListener() {
                hidePopup();
        button.setToolTipText("Button");
        final JideSplitButton jsb = new JideSplitButton();
        jsb.addActionListener(new ActionListener() {
            public void actionPerformed(final ActionEvent e) {
                System.out.println("Default option");
        jsb.setText("Select option");
        final JMenuItem item1 = new JMenuItem("Item1");
        item1.addActionListener(new ActionListener() {
                jsb.setText("Option 1");
                System.out.println("1");
        jsb.add(item1);
        final JMenuItem item2 = new JMenuItem("Item2");
        item2.addActionListener(new ActionListener() {
                jsb.setText("Option 2");
                System.out.println("2");
        jsb.add(item2);
        jsb.setPreferredSize(new Dimension(100, 20));
        getContentPane().add(jsb, BorderLayout.CENTER);
        getContentPane().add(button, BorderLayout.SOUTH);
        packPopup();
        JidePopupDemo jidePopupDemo = new JidePopupDemo();
        jidePopupDemo.showPopup();
Is there some additional configuration needed when using Java 7? I haven't been able to test the behaviour on a Windows platform.
Kind regards,
Alexander
naanab
Re: JideSplitButton not working on JidePopup using Java 7
Postby JIDE Support » Mon Jan 06, 2014 9:21 am
We are aware of the issue and fixed it (but not yet released). If you get a chance, could you build a jar from JIDE Common Layer at github and use the generated jar (just put generated jide-oss-xxx.jar before jide-common.jar in your classpath) to verify the fix?
Postby naanab » Tue Jan 07, 2014 12:55 am
I've just cloned the jide-oss project. I noticed the pom version is still 3.5.12. Couldn't find a snapshot so i packaged it anyway. Using the new jar i get the same results. JideSplitButton not working on a JidePopup. I removed the original jide-common jar from the classpath entirely to make sure the new jar is used.
naanab
Postby JIDE Support » Tue Jan 07, 2014 12:54 pm
The POM version will not be updated until we have a new release.
If that's the case, it is probably a bug on Mac JDK. Please refer to another thread here. It has a test case that you can run. JideSplitButton is a JMenu which uses JPopupMenu so it is very likely to inherit the bug.
http://www.jidesoft.com/forum/viewtopic.php?f=10&t=14950&p=73385
