conditional column summary
Postby skywalker » Mon Dec 16, 2013 12:41 pm
I'm using an Aggregate table and I want a certain column summary to be displayed only in another column of the table has been grouped. I didn't find a direct API to tell if a column is grouped so I wrote the method below. However how do I alter the summary function to disable summary based on the grouping? Is TableModelListener the right place where I call setSummaryType(PivotConstants.SUMMARY_NONE) on the field if isColumnFooGrouped() returns true?
private boolean isColumnFooGrouped() {
    int groupColumnCount = aggregateTableModel.getGroupColumnCount();
    for(int i = 0; i<groupColumnCount; i++) {
        int groupColumn = aggregateTableModel.getGroupColumnAt(i);
        String columnName = actualModel.getColumnName(groupColumn);
        if("foo".equals(columnName)) {
            return true;
Sanjiv
skywalker
Re: conditional column summary
Postby JIDE Support » Mon Dec 16, 2013 1:20 pm
Your code fraction need a little bit modification to be more accurate. Each grouping/ungrouping operation will fire table structure changed event from AggregateTableModel so you can listen to that event and check this method you provided.
        String columnName = aggregateTableModel.getActualModel().getColumnName(groupColumn);
            return true;
Postby skywalker » Mon Dec 16, 2013 1:44 pm
I was saving the actual model as a member variable but your suggestion of using aggregateTableModel.getActualModel() is better. The solution works, thanks.
skywalker
Users browsing this forum: No registered users and 143 guests
