by staiger » Fri Nov 29, 2013 1:12 am
I have the following problem with a JIdeTabbedPane:
getTabbedPane().setBackgroundAt(idx, Color.red);
does not work. The foreground is set to Color.red and blurred.
Thank you
Norbert
staiger
by JIDE Support » Fri Nov 29, 2013 11:16 am
setBackgroundAt doesn't always work for all the tab styles and L&Fs. You may try to use setTabColorProvider call instead which will work for all the cases.
by staiger » Mon Dec 02, 2013 2:06 am
Thank you.
The text is a little bit blurred, but it works.
Thank you
Norbert
staiger
