CollapsiblePane.collapse() causes painting problems
Postby dsegall » Thu Nov 07, 2013 11:08 am
I'm trying to create a collapsible pane, and set it to collapsed or expanded in code depending on certain variables. My problem is that collapse() doesn't work properly.
If I call collapse(false), the title paints properly, the icon shows as the expanded icon, but the content doesn't show until I move the mouse over the title.
If I call collapse(true), nothing paints properly.
What gives?
(Edit: Using the mouse works properly.)
dsegall
Re: CollapsiblePane.collapse() causes painting problems
Postby JIDE Support » Thu Nov 07, 2013 12:00 pm
Can you please give JIDE CollapsiblePaneDemo a try? I tried to invoke CollapisblePane#collapse() there and it works quite good for me.
Postby dsegall » Thu Nov 07, 2013 12:36 pm
I figured out what makes it tick.
After I create the components for my dialog, I have a routine that recursively goes through all the components in the dialog and changes their font. The CollapsiblePane and all of its children also get affected by this routine. The bugs only happen when I set a title on the CollapsiblePane, and whatever component it uses to display the title is affected by this font change.
Is there a way to change the font used for the CollapsiblePane's title?
dsegall
Postby JIDE Support » Thu Nov 07, 2013 2:12 pm
Please configure the UIDefaults with the key "CollapsiblePane.titleFont" to change the title font.
