Seeing entire menu with JideSplitButton
Postby robert » Mon Oct 28, 2013 1:54 pm
I am using JideSplitButton and have a case where the number of added menu items exceeds the height of the screen and so the bottom part of the menu is not visible.. Is there an easy way to visibly scroll through the entire menu. I've been experimenting by adding JMenus to the button, but I'm wondering if there is a simpler method that I have missed.
robert
Re: Seeing entire menu with JideSplitButton
Postby JIDE Support » Mon Oct 28, 2013 4:34 pm
I'm afraid that there is no easy way to have scrollable because JideSplitButton inherits JMenu. Please try to create child menu so that it could look better.
Postby robert » Mon Oct 28, 2013 7:26 pm
Thanks for the reply. I figured that was the case. I will add child menus at certain intervals so that all items are visible.
robert
