Question about using TableHeaderPopupMenuInstaller
Postby weijenli » Thu Sep 19, 2013 6:00 am
I use TableHeaderPopupMenuInstaller and TableColumnChooserPopupMenuCustomizer to make a popup menu for the table columns.
Does anyone know how do I put customized separators in the popup menu to separate menuitems?
Larry
weijenli
Re: Question about using TableHeaderPopupMenuInstaller
Postby JIDE Support » Thu Sep 19, 2013 7:14 am
In customizePopupMenu method of TableColumnChooserPopupMenuCustomizer, you have the JPopupMenu as parameter so you just call popupMenu.addSeparator().
Postby weijenli » Thu Sep 19, 2013 10:56 am
I wrote the code below, but neither AAA nor BBB showed up in the popup menu.
Did I do anything wrong?
TableHeaderPopupMenuInstaller installer = new TableHeaderPopupMenuInstaller(mytable);
JPopupMenu menu = new JPopupMenu();
JMenuItem item1 = new JMenuItem("AAA");
JMenuItem item2 = new JMenuItem("BBB");
menu.add(item1);
TableColumnChooserPopupMenuCustomizer popupCustomerizer = new TableColumnChooserPopupMenuCustomizer();
popupCustomerizer.customizePopupMenu(mytable.getTableHeader(), menu, 0);
menu.add(item2);
installer.addTableHeaderPopupMenuCustomizer(popupCustomerizer);
weijenli
Postby JIDE Support » Thu Sep 19, 2013 11:03 am
It doesn't look like you are using it correctly. Please refer to any of our demos that use installer to see an example. For example, GroupTableDemo, HeaderStyleTableDemo etc.
Postby weijenli » Thu Sep 19, 2013 11:20 am
The demo is great! thanks!
weijenli
Users browsing this forum: Bing [Bot] and 85 guests
