JidePopup with JList
Postby jitun » Tue Aug 27, 2013 3:51 am
As JList is not editable, I am trying to provide a popup by using right click button press which has a JTextArea which I expected to be editable..
I know the whole line (Jlist) can be copy pasted.. but I just want to provide copy paste certain words in the line.
but the popup/JTextArea is non editable, you you can see.. when I type something in.. it gets reflected in the JList below..
final JList<String> list = new JList<String>(LogReader.ReadLog(FilePath +File.separator+ FileName, FilePath +File.separator+ FileName1, FilePath +File.separator+ FileName2, null, null));
       list.setFont(new Font("HP Simplified", Font.PLAIN, Integer.parseInt(PropertyFile.DefaultFontSize)));
       SearchableUtils.installSearchable(list);
       list.setSelectionForeground(null);
       list.addMouseListener(new MouseAdapter()
            public void mouseReleased(MouseEvent e)
                if(e.getButton() == MouseEvent.BUTTON3)
                   System.out.println("list.getSelectedValue()" + list.getSelectedValue());
                   JidePopup _popup = new JidePopup();
                   _popup.setResizable(true);
                    _popup.setMovable(true);
                    _popup.setEnabled(true);
                    _popup.setFocusable(true);
                    JTextArea view = new JTextArea();
                    view.setRows(10);
                    view.setColumns(100);
                    view.setLineWrap(true);
                    view.setText(list.getSelectedValue());
                    view.setEditable(true);
                    view.setFocusable(true);
                    _popup.setContentPane(view);
                    _popup.setDefaultFocusComponent(view);
                    if (_popup.isPopupVisible()) {
                        _popup.hidePopup();
                    else {
                        _popup.showPopup();
list.setCellRenderer(new StyledListCellRenderer() {...
jitun
Re: JidePopup with JList
Postby JIDE Support » Tue Aug 27, 2013 11:14 am
JidePopup by default is not focusable. Please try to invoke JidePopup#setFocusable(true) and check if it could work for you.
Postby jitun » Tue Aug 27, 2013 11:25 am
The pasted code already has
As you can see i am able to search by typing on the keyboard..
So instead of focus on the popup.. the focus still is with the Jlist.
I have tried to list.setFocusable(false).. but that disables the focus from the JList.. but does not still give it to the popup.
You can try jide popup on B13.AutoCompletion or B7.SearchableComponents
jitun
Postby JIDE Support » Wed Aug 28, 2013 11:17 am
Could you please give JIDE PopupDemo a try? In that demo, you could see an editable JTextArea inside the JidePopup and it works quite well. If there is still any issue, please share with us a stand-alone test case to investigate further.
Users browsing this forum: Bing [Bot] and 81 guests
