Issue standalone and jide-properties.jar
Postby majoly » Fri Aug 16, 2013 5:28 am
Ok so here is my problem.
I use my application that can switch between a language to another.
I have a QuickFilterField declared in my application that will show a few options in the proper language.
When I use my application in IntelliJ , I have no problem whatever the language im in but when I use my application in Standalone, the only language beeing shown for this is english while the rest of my application switches to the proper language.
I have confirmed that my component is set to the proper Locale and that the jide-properties.jar is within my librairies and that everything is where it should be.
Any idea on what could be happening?
Thank you
majoly
Re: Issue standalone and jide-properties.jar
Postby majoly » Fri Aug 16, 2013 6:01 am
Forget my issue, found the problem.
The jide-properties.jar was not included in my resources and the grid.properties that was loaded was the one from jide-grids.jar.
CLOSED 8)
majoly
Postby JIDE Support » Fri Aug 16, 2013 10:45 am
Thanks for update.
