by stice » Tue Apr 30, 2013 7:17 am
Hey, i would like to enable/disable specific checkboxes after the creation of the CheckBoxTree.
Do you guys have any tips where to start?
I tried parsing the whole tree and check if the nodename is the searched one, but i cant find something like "setCheckBoxSelected"
stice
by stice » Tue Apr 30, 2013 8:29 am
tried to edit my first post, but i get an sql error:
- Code: Select all
SQL ERROR [ mysql4 ]
Column 'poll_start' cannot be null [1048]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Original Edit: With enable/disable i mean to check and uncheck a box
stice
by JIDE Support » Tue Apr 30, 2013 11:02 am
Please give the following code a try.
- Code: Select all
yourCheckBoxTree.getCheckBoxTreeSelectionModel().addSelectionPaths(yourPaths);
by stice » Tue Apr 30, 2013 4:27 pm
Worked like a charm, thanks
stice
