CheckBoxList#setCheckBoxEnabled(false) behavior
Postby pablovilas » Tue Apr 09, 2013 10:18 am
Actually CheckBoxList#setCheckBoxEnabled(false) has this behavior:
It Disables all rows components, I think this is the way that should behave:
Only checkbox it's disabled. To do that I modify CheckBoxListCellRenderer#getListCellRendererComponent() and comment:
 // copy the background and foreground for the renderer component
setBackground(listCellRendererComponent.getBackground());
listCellRendererComponent.setBackground(null);
setForeground(listCellRendererComponent.getForeground());
listCellRendererComponent.setForeground(null);
// I commented this line:
//listCellRendererComponent.setEnabled(_checkBox.isEnabled());
Thank you.
pablovilas
Re: CheckBoxList#setCheckBoxEnabled(false) behavior
Postby JIDE Support » Tue Apr 09, 2013 10:44 am
Thanks for sharing. However, we prefer to disable the text to make sure the end user won't be confused.
Postby pablovilas » Tue Apr 09, 2013 11:10 am
I see, thank you.
pablovilas
