by niteen22 » Tue Feb 05, 2013 5:20 am
I am using styledlabel to show underlined text in table column. I am using { %s:u} expression to display it and it works fine.
Now I want to make font italic as well. How should I change above expression. I tried { %s:ui} or { %s:u:f:i} but it does not work.
What is the correct way to represent above expression so that I can display underlined italic text.
niteen22
by JIDE Support » Tue Feb 05, 2013 9:29 am
Please give the following string a try.
- Code: Select all
{StyledLabel:f:red,i}
Users browsing this forum: No registered users and 73 guests
