CheckBoxListComboBox
Postby sarikap08 » Thu Nov 29, 2012 11:28 am
CheckBoxListComboBox is ComboBox which we can choose a value from a drop-down CheckBoxList.
By default after opening the list we are getting option to select OK and CANCLE Button. I want to add Select All and Select None Button.
How I can do it.Please suggest the solution.
sarikap08
Re: CheckBoxListComboBox
Postby JIDE Support » Thu Nov 29, 2012 11:54 am
Please give the following code a try. You will have to implement the action listener of these two buttons. B.T.W., I will move this thread to the "Pre-sale Support" forum since this component is not in the common layer project.
    static class CustomizeCheckBoxListComboBox extends CheckBoxListComboBox {
        public CustomizeCheckBoxListComboBox() {
            super();
        public CustomizeCheckBoxListComboBox(Object[] objects) {
            super(objects);
        public CustomizeCheckBoxListComboBox(Vector<?> objects) {
            super(objects);
        public CustomizeCheckBoxListComboBox(ComboBoxModel model) {
            super(model);
        public CustomizeCheckBoxListComboBox(Object[] objects, Class<?> clazz) {
            super(objects, clazz);
        public CustomizeCheckBoxListComboBox(Vector<?> objects, Class<?> clazz) {
        public CustomizeCheckBoxListComboBox(ComboBoxModel model, Class<?> clazz) {
            super(model, clazz);
        protected MultiSelectListChooserPanel createListChooserPanel(ComboBoxModel dataModel, Class<?> clazz, ConverterContext converterContext) {
            return new CheckBoxListChooserPanel(dataModel, clazz, converterContext,
                    getDialogOKAction(), getDialogCancelAction()) {
                protected void setupList(final JList list) {
                    super.setupList(list);
                    CustomizeCheckBoxListComboBox.this.setupList(list);
                public Component createButtonPanel(int alignment) {
                    Component buttonPanel = super.createButtonPanel(alignment);
                    if (buttonPanel instanceof ButtonPanel) {
                        ((ButtonPanel) buttonPanel).addButton(new JButton("Select All"));
                        ((ButtonPanel) buttonPanel).addButton(new JButton("Deselect All"));
                    return buttonPanel;
