accent problem on Searchable components
Postby andrednasoftware » Wed Nov 28, 2012 7:03 am
When try to type a character like " á é â " in a Searchable component, the accent is ommited.
It only appear if is the first typed character to search.
It seems to occur only on Windows platform, i've tried on Unix (Ubuntu 12.04) and it works.
//code used to make a searchable combobox
SearchableUtils.installSearchable(someJComboBox);
andrednasoftware
Re: accent problem on Searchable components
Postby JIDE Support » Wed Nov 28, 2012 9:50 am
Please try to invoke Searchable#setCaseSensitive(true) or override Searchable#compare(Object, String) to alter the default behavior. You could use the following code to get the Searchable instance.
        new ComboBoxSearchable(combobox);
Postby andrednasoftware » Wed Nov 28, 2012 10:17 am
I've tried to setCaseSensitive(true), but no success.
I don't know what to do with Searchable#compare(Object, String), my problem seems to be on the moment that i've typed the text to search.
Try the following:
1- Open an application with a Searchble ComboBox instance;
2- Click on it to gain focus;
3- Type any character and then type an '^' followed by 'a'. Normally it will produce a 'â' character, but it doesn't happen.
andrednasoftware
Postby JIDE Support » Wed Nov 28, 2012 11:39 am
Could you please let me know the keyboard you are using? I could use ` + 'a' to type in à with United States International Keyboard but not the way how you input â. Also did you ever input it correctly in other Swing components like JTextField?
Postby andrednasoftware » Wed Nov 28, 2012 11:57 am
My keyboard layout is Portuguese (Brazil - ABNT2).
I never had problem inputting characters like this in other Swing components.
This behavior only happened on Windows (in my case Windows XP SP3), testing in Unix (Ubuntu) works fine.
andrednasoftware
Postby JIDE Support » Wed Nov 28, 2012 1:57 pm
Reproduced and will keep you posted when we figure out how we could solve the issue.
Postby andrednasoftware » Thu Jan 31, 2013 12:08 pm
Just to know if there is a prevision for solving this problem.
andrednasoftware
Postby JIDE Support » Thu Jan 31, 2013 1:02 pm
Sorry that no progress here yet.
Users browsing this forum: Bing [Bot] and 87 guests
