Editing Table
Editing Table
Postby blurbs » Sun Nov 25, 2012 6:51 pm
Hi there,
Greetings.
I'm a new here.
I want to ask some questions regarding editing cell in a table.
Currently my practices of doing cell editing in a table is by double-clicking the cell to make the cell editable for text input.
For the single-clicking, it will select the row instead. It just like Excel behaviour of cell editing.
What I see in some of JIDE demo, some of the table can be editable using single-click and some of it can be editable using double-clicking.
What I want to know here is the best practices of cell editing in a table whether it is single-click or double-click?
Is there any issue if we use double-click to edit the table compared to the single-click to edit the table?
Hope you all can help me,
Thanks! :D
blurbs
Re: Editing Table
Postby JIDE Support » Mon Nov 26, 2012 11:19 am
I believe this is the choice of your application. If you are more concerned about avoiding error inputs from the end user, it might be appropriate to double click to edit. If you are more concerned about the easier input to treat your end user more friendly, single click to edit would be the solution.
Users browsing this forum: Bing [Bot] and 89 guests
