by acallies » Wed Nov 14, 2012 6:00 am
I created a DualTable and I am not able to sort the right panel (the selected items panel) whereas I can sort the left panel. Both panels have the same columns...
Do you have an idea how I could do to be able to sort the right panel?
Thank you in advance.
acallies
by acallies » Wed Nov 14, 2012 6:15 am
Problem solved by a simple : dualTable.getSelectedTable().setAutoCreateRowSorter(true);
acallies
by JIDE Support » Wed Nov 14, 2012 9:36 am
The selected table in DualTable is not supposed to be sorted since some of our customers will require order during the selected records. The JTable API might help your case but it may also pop up some other problems later so it's not recommended.
Users browsing this forum: Bing [Bot] and 86 guests
