by staiger » Wed Nov 07, 2012 8:21 am
I try to call installSearchable for my tree (which uses StyledLabels as nodes).
But the leaf nodes where not found.
Is there a solution for this problem?
Norbert
staiger
by JIDE Support » Wed Nov 07, 2012 11:17 am
Please override the TreeSearchable#convertElementToString() to achieve your goal.
- Code: Select all
new TreeSearchable(tree) {
protected String convertElementToString(Object object) {
// convert your node here
return super.convertElementToString(object);
Users browsing this forum: Bing [Bot] and 90 guests
