PointSpinner value not reflected in focus lost
Postby rathinamsm » Sun Oct 14, 2012 11:42 pm
Hi Team,
I tried a sample using the Point Spinner Demo. In that,
When i enter the values as 100,200 and pressed the button using mouse to get the values from the Point spinner, it returns the old value. ( Note: Even though I triggered button action using mouse )
When i press tab from the spinner then value the value changed to (100,200) and the value gets reflected.
Please let us know...
rathinamsm
Re: PointSpinner value not reflected in focus lost
Postby JIDE Support » Mon Oct 15, 2012 8:46 am
It works fine on my end. Could you please give us more details about your testing? For example, the test case and the release of JIDE you used, the steps you tested. A screencast will be good.
Postby rathinamsm » Wed Oct 17, 2012 10:52 pm
Hi Team,
Please follow the sample below.
Scenario 1:
1. enter the value as 100,200
2. press the button to get the value
3. it will print as 0.
Expected : 100,200
But the working steps is:
1. enter the value 200,200
2. press enter key
3. press the button and the print msg will be 200,200
Please resolve this.
Hope now you understood.
( And i noticed that the focus listener is not working in the point spinner. )
import java.awt.BorderLayout;
import java.awt.Component;
import java.awt.event.FocusEvent;
import java.awt.event.FocusListener;
import com.jidesoft.spinner.PointSpinner;
import com.jidesoft.swing.JideButton;
public class PointSpinnerDemo1 extends JFrame {
   PointSpinnerDemo1() {
      setTitle( "Focus retained problem" );
      getContentPane().add( getDemoPanel() );
      pack();
      setVisible( true );
      JPanel panel = new JPanel();
      panel.setLayout( new BorderLayout() );
      final PointSpinner pointSpinner = new PointSpinner();
      panel.add( pointSpinner, BorderLayout.CENTER );
      final JideButton jbtn = new JideButton( "Press To Get Value" );
      jbtn.addActionListener( new ActionListener() {
            System.out.println( "Value : " + pointSpinner.getValue() );
      panel.add( jbtn, BorderLayout.NORTH );
      pointSpinner.addFocusListener( new FocusListener() {
         public void focusLost(FocusEvent e) {
            System.out.println( "--How to call this--------------fl" );
            jbtn.doClick();
         public void focusGained(FocusEvent e) {
      return panel;
      new PointSpinnerDemo1();
rathinamsm
Postby JIDE Support » Thu Oct 18, 2012 1:18 pm
It is as designed. The input will be set back to model when the text field lose focus or user input enter. If you want to get the value in your case, please commit it by yourself.
                    ((PointSpinner.PointEditor)pointSpinner.getEditor()).getTextField().commitEdit();
                catch (ParseException e1) {
                    e1.printStackTrace();
