Disable Menu Items in JideSplitButton
Postby judodan » Mon Sep 17, 2012 12:33 pm
Is there a way to disable menu items in a JideSplitButton? I want to disable only some of the menu items when the menu is opened. I couldn't find any example code to do this.
Thanks!
judodan
Re: Disable Menu Items in JideSplitButton
Postby JIDE Support » Mon Sep 17, 2012 1:55 pm
Please invoke Action#setEnabled() to control the behavior of the menu items. The sample code is posted below.
        final JideSplitButton button = new JideSplitButton(name);
        AbstractAction action0 = new AbstractAction("Sample Menu Item 1") {
        action0.setEnabled(false);
        button.add(action0);
        AbstractAction action1 = new AbstractAction("Sample Menu Item 2") {
        button.add(action1);
Postby judodan » Mon Sep 17, 2012 2:21 pm
It's not actually that simple. Because I'm keeping a list of fields (to sort on), every time I open the popup, I want to enable/disable the selection based on what is visible in the listbox (should not be able to add the same field twice). From your hint, I was able to resolve this by adding a PopupListener. Code is included below in case someone else has same issue:
       jAddSortButton.getPopupMenu().addPopupMenuListener(new PopupMenuListener() {
           public void popupMenuWillBecomeVisible(PopupMenuEvent evt) {
               JPopupMenu menu = (JPopupMenu) evt.getSource();
               DefaultListModel model = (DefaultListModel)jSortList.getModel();
               for (Component child : menu.getComponents()) {
                   if (child instanceof JMenuItem) {
                       JMenuItem item = (JMenuItem)child;
                       boolean enabled = !model.contains(item.getText());
                       item.setEnabled(enabled);
           public void popupMenuWillBecomeInvisible(PopupMenuEvent evt) {
           public void popupMenuCanceled(PopupMenuEvent evt) {
Works great now!
judodan
Postby JIDE Support » Mon Sep 17, 2012 2:30 pm
Glad to know that you had worked it out. And thanks for your sharing.
